Co-author: Rob Koehler
Already, fans of Microsoft Power Automate (previously called Flow) will know that it’s a great tool for streamlining repetitive tasks and making processes paperless. It’s why the tool is such a great fit with Docusign – we’re all about going paperless and automating key tasks, too.
Our example: Creating a workflow when a new file is created in SharePoint
In procurement, a trigger could occur when a tender/project status is changed in a SharePoint list to automatically send an approved contract for execution
In HR onboarding, when a new employee is added, the onboarding pack (personal profile, payroll data collection, NDA, etc) is automatically sent through an approval and signature workflow
Step 1: Docusign Setup
Login to Docusign Admin and make a note of your Account ID (see top left)
Create an Integration Key, a special key that enables the API-level authentication:
Go to Integrations > API and Keys, and note down the “Account’s Base URI”. We will refer to this as the Base URL.
then “Add App / Integration Key”, note down the Integration Key
Select “Authorization Code Grant” radio button, then click “Add Secret Key”, and note down the Secret Key
Click “Add URI”, and add the following: https://global.consent.azure-apim.net/redirect (this may change as its generated by Power automate, but this initial value will work for now). Please note down this value of the Redirect URI for now.
Create Custom Fields
Go to Signing and Sending > Document Custom Fields, click “Add Field”
Choose which fields you’d like to add (e.g. signature, name, signing date) and follow the prompts. For example, if you want to add a Signature field, the recommended values are:
Type: Sign Here
Shared: Tick (yes)
AutoPlace Text: \s{r}\
Create a Custom Connector
General
Input these details below:
Host: Base URL [captured earlier]
Base URL: /restapi/v2.1
Security
DEMO:
IKey: Integration Key [captured earlier]
Secret Key: Secret Key [captured earlier]
Authorization URL (DEMO): https://account-d.docusign.com/oauth/auth
Token URL (DEMO): https://account-d.docusign.com/oauth/token
Refresh URL (DEMO): https://account-d.docusign.com/oauth/token
Scope: signature extended
PROD:
Authorization URL (PROD): https://account.docusign.com/oauth/auth
Token URL (PROD): https://account.docusign.com/oauth/token
Refresh URL (PROD): https://account.docusign.com/oauth/token
Definition
Enter these values:
Verb: POST
URL: https://demo.docusign.net/restapi/v2.1/accounts/\[your Account ID]/envelopes
Body:
"documents": [
"documentId": "1",
"fileExtension": "txt",
"name": "Doc1",
"order": "1"
"recipients": {
"signers": [
"recipientId": "1",
"roleName": "Signer 1",
"routingOrder": "1"
"status": "sent"
Test
Inputs:
Site Address: - Sharepoint site
Folder id: Folder path
Get file content
Inputs:
Site Address: Sharepoint site
File identifier: – This is the output from the previous step. Simply select “File identifier” under “dynamics content” on the right pane. See above screenshot.
Compose
Input
Inputs: “base64(…)” – within the brackets, go to “dynamic content” and select the “Get file content” (As below). The final function should read:
base64(body('Get_file_content'))
Add Custom connector
Select the Action we created.
Now add the following values:
documentId: 1
fileExtension: txt
order: 1
emailSubject: Send document for signature
email: [enter signer email address]
name: [enter signer name]
recipientId: 1
roleName: Signer 1
routingOrder: 1
status: sent
Note - For these fields:
Now save and run it!
Mo is a Principal Solution Architect with over 20 years of experience working with companies of all sizes, helping them realise their digital strategies. Mo is based on Australia, loves all things low-code, architecture, and is currently attempting to master the art of dad jokes.
- DevelopersPublished Mar 11, 2025
How to set up Salesforce authentication with JWT to access any Docusign API
