Author Docusign Contributor
Published 23 July 2021
Summary8 min read
Already, fans of Microsoft Power Automate (previously called Flow) will know that it’s a great tool for streamlining repetitive tasks and making processes paperless. It’s why the tool is such a great fit with Docusign – we’re all about going paperless and automating key tasks, too.
Our example: Creating a workflow when a new file is created in SharePoint
  • In procurement, a trigger could occur when a tender/project status is changed in a SharePoint list to automatically send an approved contract for execution
  • In HR onboarding, when a new employee is added, the onboarding pack (personal profile, payroll data collection, NDA, etc) is automatically sent through an approval and signature workflow
Step 1: Docusign Setup
  1. Login to Docusign Admin and make a note of your Account ID (see top left)
  2. Create an Integration Key, a special key that enables the API-level authentication:
  • Go to Integrations > API and Keys, and note down the “Account’s Base URI”. We will refer to this as the Base URL.
  • then “Add App / Integration Key”, note down the Integration Key
  • Select “Authorization Code Grant” radio button, then click “Add Secret Key”, and note down the Secret Key
  • Click “Add URI”, and add the following: https://global.consent.azure-apim.net/redirect (this may change as its generated by Power automate, but this initial value will work for now). Please note down this value of the Redirect URI for now.
  1. Create Custom Fields
- Go to Signing and Sending > Document Custom Fields, click “Add Field”
- Choose which fields you’d like to add (e.g. signature, name, signing date) and follow the prompts. For example, if you want to add a Signature field, the recommended values are:
a.  Name: Signature
b.  Type: Sign Here
c.  Shared: Tick (yes)
d.  AutoPlace Text: \s{r}\
Step 2
Step 3
Create a Custom Connector
Custom Connector
Connector name
General
Input these details below:
  • Host: Base URL [captured earlier]
  • Base URL: /restapi/v2.1
Upload connector
Security
DEMO:
PROD:
Security
Create connector
Definition
Send document to sign
Enter these values
Verb: POST
URL: https://demo.docusign.net/restapi/v2.1/accounts/\[your Account ID]/envelopes
Body:
  "documents": [
      "documentId": "1",
      "fileExtension": "txt",
      "name": "Doc1",
      "order": "1"
  "recipients": {
    "signers": [
        "recipientId": "1",
        "roleName": "Signer 1",
        "routingOrder": "1"
  "status": "sent"
Send document to sign 2
Select “Import” to complete this section
Import
Test
Test connection
Create steps in flow
Inputs:
  • Site Address: - Sharepoint site
  • Folder id: Folder path
Next step in flow
Get file content
Inputs:
  • Site Address: Sharepoint site
  • File identifier: – This is the output from the previous step. Simply select “File identifier” under “dynamics content” on the right pane. See above screenshot.
Compose
Connector name
Input
  • Inputs: “base64(…)” – within the brackets, go to “dynamic content” and select the “Get file content” (As below). The final function should read: base64(body('Get_file_content'))
Add Custom connector
Add custom connector
Select the Action we created.
Connector name
Now add the following values:
documentId: 1
fileExtension: txt
order: 1
emailSubject: Send document for signature
email: [enter signer email address]
name: [enter signer name]
recipientId: 1
roleName: Signer 1
routingOrder: 1
status: sent
Note - For these fields:
Now save and run it!
