Obtain identity workflows available on your account (using the IdentityVerification:list API) and extract the workflowId
associated with the one that you’d like to use.
Request:
Headers:
Authorization: Bearer {code}
Response:
"identityVerification": [
"workflowId": "{workflowID}",
"workflowLabel": null,
"steps": [
"name": "identify",
"type": "EnvelopeAccess"
"signatureProvider": null,
"inputOptions": []
"workflowResourceKey": "",
"steps": [
"inputOptions": [
"isRequired": true,
Request:
Headers:
JSON Payload:
"compositeTemplates": [
"serverTemplates": [
"sequence": "1",
"templateId": "{templateId}"
"inlineTemplates": [
"recipients": {
"signers": [
"email": "{recipientEmail}",
"name": "{recipientName}",
"recipientId": "1",
"identityVerification": {
"workflowId": "{workflowId}",
"steps": null,
"inputOptions": [
"name": "phone_number_list",
"phoneNumberList": [
"sequence": "2"
"status": "sent"
Response:
"status": "sent"
Ahmed Shorim has been with Docusign since 2021 as a Senior Developer Support Advisory Engineer. His work is focused on advising developers on how to integrate with Docusign APIs and SDKs by consulting on best practices and providing code examples. Experienced in developing web, mobile, and desktop applications along with building automation flows, he can be reached at LinkedIn.
