Author Zing Zai Loo
Published Mar 2, 2022
Summary3 min read
In Oct 2021, Salesforce announced that Workflow Rules and Process Builder would be retired in the near future. Building flows using Flow Builder will be the way forward where it would be a one-stop shop for low-code automation.
Why Smooth Flow?
DocuSign Envelope Status component
Smooth Flow updates the object’s Chatter post whenever an envelope status changes. I have saved Smooth Flow for last in my blog series as it is so smooth, it applies to envelopes sent in Part 1 and Part 2.
Example
DocuSign envelope status in Chatter update
The setup
Setting up Smooth Flow
Selecting a new Record-Triggered Flow
Configuring the trigger
Step 2: Get records
Adding the first Get Record data element
Step 3: Create new resource
Creating a new Text Template resource
Step 4: Update Chatter
Creating a new action to update Chatter
Author Zing Zai Loo
